Not the dimmer switch it's the 2 sensors under the seats that need replacing but my mechanic sais this us not a guarantee that the lights will go out. The carpets are damp due to water getting in, we don't know. I'm heart broken as I may have to sell it for parts :-(
Make sure the drainage holes for the convertible top are not clogged up. They are located on each side of the car behind to doors when they are closed. Water not draining from the top will end up on the floors possibly causing electrical shorts.
In the picture, right behind the seats, you see the frame of the roof. Two pieces of the frame come together there at a hinge. Look between that hinge and the body of the car and you will see a hole about the size of your little finger. You can open up a clothes hanger and run it down that hole as far as you can to unclog it. The bottom of the hole is in front of the rear wheel on the underside of the car. If its possible, you can stick the nozzle of an air hose against the opening to blow it out (at the top of the hole). You can test to see if its open by carefully pouring some water down the hole. The opening of the hole that you see is located in a small rectangular compartment. When you look for it, it is difficult to see. You might see the rectangular compartment but not be able to see the hole at the bottom of it because you can't get your head in a position for a direct line of sight. When you pour the water into the compartment, it should drain out the bottom of the car right away. If not, its still clogged. Once you've done this, allow the car to dry out. Some people who scrub out their rugs actually place a small fan in or at the car for a few hours to dry it out more quickly. If you're lucky, any wires that were wet might dry out enough so that things get back to normal. Good luck with this. Frankie (after midnight in Egg Harbor Township, New Jersey.)
PS I had a picture of the hole but I can't find it now. I've posted it on the forum before. Perhaps our fearless leader
@GazHyde can find it for me.
