@t-tony you hit the nail on the head mate.
Hose going to the master cylinder was clogged, luckily the blockage was at the top of the hose rather than the end of it as that would have required the removal of the master cylinder.
After getting rid of the blockage and topping up with fluid I was able to get fluid coming out of the clutch hose. As I had removed the slave cylinder I had to bleed it, this was an absolute pain in the backside. Got all of the bubbles out of it with it detached, then fit the clutch hose and reinstalled the slave in the bell housing.
I bought a cheap one man bleeder kit from halfords and bled the clutch from the nipple once the slave was attached.
I wasn't sure if the the brakes would need bleeding but I was so excited to use my one man bleeder kit again that I bled brakes again anyway.
As
@FRANKIE had suggested taking the seat out made accessing the master cylinder a lot easier. I also removed the steering wheel and all the lower trim from within the car. This is the only way i was able to slide the pins back on to the pedal assembly and get the clips back on.
I spent most of today doing all of that and is by no means a quick job. The good thing is that the pressure is back on the clutch pedal and it engages/disengages correctly again.
I did face an issue with the brake light being permanently on after getting everything back in, and Frankies video helped with this. There is a switch near the brake pedal which will cause the brake light to turn on when there is no pressure on the switch. Essentially the switch was knocked out of alignment and a quick pry with a flat blade screw driver quickly fixed this.
Many Thanks to everyone that helped.
