Buying a Z3M
Medskipper
Surrey
Z3M & Z3 1.9.
Hi guys!
I’ve just put a holding deposit on a beautiful year 2000, Z3M with the S54 engine £78k miles and will be inspecting it next week.
Can any of you knowledgeable people tell me what really important things I should be looking for with a car like this?
I already own a really nice year 2000 Z3 1.9. So I’m well aware of bodywork things to look out for but I’m looking for advice on the large lump under the bonnet! How to spot Vanos problems etc.
Possible problems with emissions or anything else that I should be aware of as I don’t want to make an expensive mistake!
Very grateful for helpful advice, and looking forward to posting pics shortly,
Barry
Welcome to the club :welcome:
Service history, Boot floor spot welds, Vanos rattle, clunking from the diff when pulling off/lifting off. ANY smoke from the exhaust.
Rest is the same as other Z3s, bushes, brakes. rusty sills etc
@Pingu will probably be a good source of advice.
Ianmc
New Forest
Z3 (M44)
Are you sure it's a S54? These were 2001/2 I believe.
Pingu
The main unique issues are what @Nodzed said.
I would check for service history. I'd want to do a valve clearance check (done properly), unless you are 100% confident that it was done properly at the last service.
All oils, fluids and filters should have been changed by now. Look for evidence that gearbox oil, diff oil, brake fluid, coolant, power steering fluid and fuel filter have all been changed. All are additional items to a BMW inspection.
If you are not handy in your coveralls, get an RAC inspection.
Medskipper
Surrey
Z3M & Z3 1.9.
Right , just the sort of info I need! Dealer stated it’s an S54!
So I sense a porky pie?
Would anyone know what a year 2000 Z3M has? It’s a W reg so early part of the year 2000?
Keep it coming guys!
Medskipper
Surrey
Z3M & Z3 1.9.
This is a picture of the engine,
Mark Gutteridge
Had mine 10 years never failed in any way.
I did upgrade the vanos bolts.
Changed the gearbox and diff oils.
That's it.
Ianmc
New Forest
Z3 (M44)
S54 cars attract a significant premium over S50 cars; it is most unlikely that a 2000 car is a S54.
Medskipper
Surrey
Z3M & Z3 1.9.
Would having the S50 engine stop anybody buying the car?
Or should I carry on searching for a Z3M with an S54?
Pingu
They are much the same.
I defy anyone to tell the difference from the driver's seat (yes, I know the gauges are slightly different, but I hope you know what I mean).
However, the S54 will always be a premium as there are only 73 RHD ones.
It's like a rare £1 coin. It's only worth more than £1 to someone who collects £1 coins. To someone who just uses £1 coins to spend money, it is just another £1 coin.
Re S54 v S50, there are two potentially catastrophic areas of the engine. The VANOS and the big-end bolts.
Big-end bolts are as likely to fail on either and equally catastrophic.
If the VANOS cover bolts on an S50 fail, the result is a very noisy VANOS and lots of oil. Engine failure is as a result of loss of oil.
If the VANOS sprocket bolts fail on an S54, the result is catastrophic damage to the top of the engine if you don't catch it in time.
Medskipper
Surrey
Z3M & Z3 1.9.
Great comparison! Thanks
Medskipper
Surrey
Z3M & Z3 1.9.
Pingo says there were only 73 RHD produced with S54 engines.
Do any on you experts out there know how many were produced with the S50 engine?
Just for the matter of interest!
Barry
Pingu
I notice that one has cruise control. It's quite rare to see that on an S50 as it is electro-mechanical and not an easy retro-fit. S54 cruise control is just plug'n'play.
