its a bit over kill really, this tiny speaker peaks at 600Watts, don't think it will ever see anything near it, maybe 150 at most as my ears are not getting any younger
but as long as I keep within Susan's dimensions I should be ok, I'm watching a few amps on ebay but I'm open to suggestions. I don't think the bolts actually do anything, typical Italian - just there for aesthetics as the magnet under the rubber cover is just plain (Chinese looking) but for the price its quite sturdy (a bit weighty, I once called a girl sturdy, got a shiner thrown in for free, I ended up living with this girl for about 6 years after) don't want to go mad on the amp, maybe 300w max (not peak watts)
had to remover the rubber mounting ring and mount the driver from the inside, i also had to take out the screws at the back (just as i thought, a half harted attempt to hold the glued on rubber cover) so with rubber and screws removed it still was tight, so i also removed the metal cover on the back and replaced it with a mesh, now it fits great, but will it run ok without the rear part
right, next part is the amp (picking a couple up on Saturday (cheap - £10 each, will sell the one i dont use, one at 250w and the other is 400w both two channel - bridgeable) .It all sounds a bit tight pal, good luck, I hope you get a great sound, must get on with minebox is done, phew. final depth is 94mm, susans was 100mm so im hoping the 6mm left is enough for the driver to move without hitting the cross memberhad to remover the rubber mounting ring and mount the driver from the inside, i also had to take out the screws at the back (just as i thought, a half harted attempt to hold the glued on rubber cover) so with rubber and screws removed it still was tight, so i also removed the metal cover on the back and replaced it with a mesh, now it fits great, but will it run ok without the rear part
depth is the tightest part, susans plans has the outside depth at 100mm, then she added some carpet, not sure if i can go over 100mm so kept within that, would be nice to have even just another 5mm in depth.Which dimensions would I use having roll hoopsits slightly lower that susans in height, but i cant go that much lower as the 6.5 inch driver wont fitdepth is the tightest part, susans plans has the outside depth at 100mm, then she added some carpet, not sure if i can go over 100mm so kept within that, would be nice to have even just another 5mm in depth.
the problem with the height is the 6.5 inch driver is 165mm, the same height as susans box. how high was yours?
susans, i could go wider (no hoops) but im also sticking to susans dimensions. just trying to find out how high to go to retain the original lidWhich dimensions would I use having roll hoops
. theirs gona be a big pile of unused/wrong sized boxes piling upAs you have the tools and skills to make this perfectly its a good sale item in my view only place that makes and sells them charges £150 and then you have uk postage on that!hopefully it will be dry and sunny at the weekend, then i can strip the cubby out and get a better idea of how much space there is or isn't. theirs gona be a big pile of unused/wrong sized boxes piling up
lucky it doesn't cost me anything.
