I tested a 2006 E85 Z4 today and when I looked at the front inner brake pipes which go to the flexible hoses they looked eminently passable. For some reason I lifted the plastic wing liner and it was a different story.
And on closer inspection I wouldn't want this on my car.
You're not obliged to look under covers etc. but I've seen similar on old Freelanders and known pipes burst in a place where you couldn't see the pipe.
So the moral of the story is, if you own an older Z4 have a good luck and see if yours are ok. Easy job to change, n/s one has loads of room near the bulkhead to join a new piece of pipe in and the o/s one goes directly to the ABS pump.
