You need to eat more weetabix !!!!I think you can fit the poly bushes by hand. But the issue you will have is getting the old bushes out. I physically couldn't
At this rate mate it will be quicker for you to drive down to me.Took it to another garage he said he can' get his press on it as there is no support on the other side. Said I should cut them both out and buy poly.
Nice one! Might do the deed£46 for a pair of strong flex bushes
http://www.strongflexuk.co.uk/bmw/z-series/z3/rear-beam-mounting-bush.html#.Wtp8eS_MzOQ
Bloody hell that's cheap. HmmmmTry Dura flex i have there lollipop and anti roll bar bushes fitted and find them good.
They list a complete rear poly set for £41
It lists as a compact but the zed uses the same rear end i believe. If you message them they are a wealth of knowledge and will help steer you to the right part
Thanks for the link pal, bookmarked it£46 for a pair of strong flex bushes
Bloody hell thats cheap, might order a set of thoseTry Dura flex i have there lollipop and anti roll bar bushes fitted and find them good.
Just ordered a set, £47 all inTry Dura flex i have there lollipop and anti roll bar bushes fitted and find them good.
Ordered a set tooJust ordered a set, £47 all in![]()
I have them fitted and @t-tony has them also no issue tightened the front end nicelyanyone used the front lollipop bushes from duraflex... they seem very cheap and is that for a pair... £14.95 !!!
http://www.duraflexpubushes.com/bmw-e30e36--front-wishbone-rear-bushes-391-p.asp
Happy with mine too Ant. I gave then a liberal spray of silicone before pressing them into the alloy housings.I have them fitted and @t-tony has them also no issue tightened the front end nicely![]()
