You have a MAF fitted together with O2 sensors, so your fuel air ratio is always kept at the correct ratio, so in theory more air equals more fuel which equals bigger bang which equals more power.DirtyDog yes it is, but as in my photo of the filter fitted if you want to use the extension you will have to make an adapter?
further to fitting this the fuel consumption has dropped a lot? so I think as the filter allows more air into the engine the ECU now pumps
more fuel to accommodate the increase in air? so my thoughts are that you don't get an increase in BHP but an in crease in fuel injected / used to allow for the air increase, I know there is a formula as to air to fuel ratio but I'm not sure what it is so be prepared to use more fuel?
I'm sure somebody will have another opinion? come on guys lets have it.![]()
Looking at the pictures posted on here I guess all the engines are M44 or similar where the oem filter/housing is taken out and the cone style filter just just pushes on.
On my M43 engine I can remove the OEM filter and housing ok but there is also another pipe running from the airbox to the emission control air pump which also I guess needs a filter on it or some kind of adapter pipe to work.
Has anyone done this on a M43 engine?
Its the least of my worries at the moment ., but I do find it easier checking/working on the car without the huge air box in the way.
Removing that smog pump won't give you any problems whatsoever. If it's the same as on my 2.0 there is an electrical connection for the motor and one vacc pipe which you plug up.
Ok, sorry my info no help mate. Hope you find a way round it.
