Did you get them shot-blasted @Mario ? I've always wondered if that affects the spring but presumably not? I probably just read something ages ago and mis-remembered.If you still need a set I have a set of -30mm that I have sent for powdercoating in black - PM me for details
Not heard of that before. Who is that then?I basically stripped it 99% myself then they put it on that container of small beads that vibrates
That's the conclusion of that article.I did some research before going ahead with this, it's not the blasting but the operators using too high temperature when baking the powder coating that can affect some alloys, springs are theoretically of stronger materials than alloys so they should be OK at alloy safe temperatures
I would think so. The issue with springs is when the original coating flakes off as it flexes then the rust starts.Makes sense to me. In the past someone suggested Plasti-dipping springs but I can't see that would work, at least not for long. The thinner the coatings the better I would have thought.
Very true Rob, I often see cars which have had a "new" spring and generally the black paint will last up to 2 years or more and that's on every day use cars, the first point of corrosion usually is where the first coil "hits" the square cut end of the spring, and, quite often this is where the spring will break! It makes me think that many broken springs could be avoided by grinding the cut end down to a taper. This would obviously cost more in manufacturing but not that much.I would think so. The issue with springs is when the original coating flakes off as it flexes then the rust starts.
