Wanted 30mm lowering springs wanted
Mario
If you still need a set I have a set of -30mm that I have sent for powdercoating in black - PM me for details
mrscalex
Did you get them shot-blasted @Mario ? I've always wondered if that affects the spring but presumably not? I probably just read something ages ago and mis-remembered.
Mario
I basically stripped it 99% myself then they put it on that container of small beads that vibrates
Mario
It's becoming very common for small parts I have seen it on other places. The powder coating was max powder in hemel but the prep I took it to a local metal plating guy as I had to take some small bits to be re chromed and he put the springs on the machine for me while I was there,they came out amazing
Mario
I did some research before going ahead with this, it's not the blasting but the operators using too high temperature when baking the powder coating that can affect some alloys, springs are theoretically of stronger materials than alloys so they should be OK at alloy safe temperatures
mrscalex
That's the conclusion of that article.
Makes sense to me. In the past someone suggested Plasti-dipping springs but I can't see that would work, at least not for long. The thinner the coatings the better I would have thought.
mrscalex
I would think so. The issue with springs is when the original coating flakes off as it flexes then the rust starts.
Very true Rob, I often see cars which have had a "new" spring and generally the black paint will last up to 2 years or more and that's on every day use cars, the first point of corrosion usually is where the first coil "hits" the square cut end of the spring, and, quite often this is where the spring will break! It makes me think that many broken springs could be avoided by grinding the cut end down to a taper. This would obviously cost more in manufacturing but not that much.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
I used to have a motorbike that had powder coated springs on the shocks. They were OK during my ownership. It's quite common for bike shock springs to be powder coated.
Think back to the days of the 1970's custom car scene when it was very popular to have your springs chrome plated or even whole axle set ups.
Some Zeds wouldn't leave the garage if they had chrome springs =))
2DunnsZ3
Canton USA
Z3 2.8 5 speed roadster
I am so jealous that I am waaaay across the pond. would love to lower the rear of my Zed and hang out with you guys. If you look at my fall pics under the tree. you can see the front lowered and the rear is not. they look so much better down and dirty
