Dreamofz
- Joined
- Jul 7, 2026
- Points
- 13
Evening all
I have the face lift with the side markers in the bumper, this evening I noticed both the passenger side rear light and sidelight would not come in on at all however all other lights inside and outside work as expected. I switched the bulbs with working ones from the drivers side and still no light so I knew it wasn’t the bulbs, I then checked the relevant fuses in the fuse box which looked fine but I replaced them anyway, so I’m not sure what to try next?
Im not sure if it’s relevant but I have been under the same side wing carpet recently, removing the electric roof pump and also removing the cd changer unit in the boot, wondering if I’ve perhaps moved a wire or broken something related as it’s all on the passenger side of the car the issue has occurred.
Thanks if you can help with things to try next
