A bit of Saturday Zedness
Simon Blythe
South Birmingham
replaced the thermostat earlier today and had a little company
As I've now replaced the thermostat, water pump and vicious coupling, I know how to do it now so if anyone needs a hand doing theirs then let me know.
They look soooo good together :happy:
Is it a forum members?
Well get him or her signed up on the forum! You get 10 years for not putting friends forward round here! ;)
You dont hang about :thumbsup:
Is the over cooling cured Simon?
Good!
I priced the parts at under £100 where did you get them from?
Yes ma
yes mate it is but it's still a little cool from the vents but I think there's still air in the system.
Parts aren't cheap to do it
Check the heater control cable it may need need adjusting you'll find the adjuster either under the footwell upper cover or behind the footwell inside cover on the clutch side cant remember off hand, pretty sure there's a thread on here some where or perhaps some kind member will jump on and be more specific. Or get the car on a steep hill nose up and bleed it if there is any air in the heater matrix it should come out but should bleed OK without doing this.
