- Joined
- Oct 13, 2017
- Points
- 64
- Location
- Llandrindod Wells, Powys
- Model of Z
- Z4 SDrive 23i M Sport 2.5Ltr. H.T Convertable
Took Zed in this morning. Russ was unable to get him on the ramp as it was already occupied. So, off to do some shopping at the local factors for oil, oil filter and other bits. Wallet felt lighter on the way out.
Went to the local D.I.Y. emporium for washers for the new brake hoses. I couldn't find any large ones with the required 14mm center, so bought some with smaller center's with the plan to drill them to size. Not looking forward to that, I'd like to keep all of my digits, thank you very much! However, there were some square ones there which fitted the bill, but, and this is where @t-tony comes in, they are quite a bit thicker. (I know this because I asked them a question and they didn't know the answer) so, Tony, or anyone else, these must be around 2 to 3mm thick. Do you think they would fit in okay or will they be too thick? I can see from your excellent write up, Tony, that the 'penny washers' are the same size as the ones I have bought, apart from the center. I have not yet had a look at the brake lines as the lad was working on the panels when I got back.
While I was in the D.I.Y store I met Russ there, he said he had removed the headlight that was broken, and the bad news is that two of the lugs were beyond repair. That, plus the build up of condensation, made it a 'no-brainer' for getting it replaced. Ordered one online (S/H). Wallet felt a lot lighter.
I am going to replace the bulbs in the headlights for the 'Night Breaker' type. But can anyone advise me which ones to get? I have seen Osram N.B 'Unlimited H4', N.B.'Laser H4', Osram N.B.'Unlimited H7' and many more. Am I right in thinking that I need the 'H7' type? Please tell me I am right, as these are in a 'twin pack' and are a bit cheaper than buying singles. Moths in the wallet starting to get hungry.
I shall be back in tomorrow and see if I can either start on the brake lines or do the oil change. Hopefully, photo's to follow.
Found some old dollar bills from a long forgotten holiday, put them in my wallet. Moths seem to be content for now.
Colin.
Colin.
