How To Guide Z4 roof motor relocation to boot
CrazyOneToo
Crazyone, there is no need to replace the motor, you are looking at £600 from BMW. Put your motor in a container of diesel overnight, in the morning squirt the brushes with wd40 or my favourite gt85, a few light taps with hammer to free the brushes and it will work when reconnected, if it doesn't tap it lightly when it is connected....run it at full tilt for a couple of mins to clean up the rotor and brushes.
:thumbsup:
RalphyM
I had to sign up just to say thanks to the original poster for the write up. My z4 succumbed to the dreaded dying roof but is now fully operational again. Saving me a shed load of £££.
Definitely not the easiest job in the world unless you have long arms and small hands but is actually quite straightforward.
I could pry the case out so used the drill a hole and Allen key trick to get enough purchase.
Thanks again!
Hi Ralph, welcome from me near Lincoln. Congrats on getting the roof motor done, one of the most regular ailments of the E85. Where are you located please? Oh, and please show us some pictures of your car, we all like pictures.:)
RalphyM
I’m just outside Andover. Have put an intro thread up! I’ll have to dig out some pics as well...
Where are you located Simon?
Paul Milligan
Well, my missus's Z4 succumbed to the renowned roof motor failure last week.
Windows drop, roof unlatches then nothing.
So I set about a repair and decided to photograph what I did to get it, not only working, but relocated as well.
The main problem with the Z4 roof motor is its location.
The motor, surrounded by some sound proofing foam, sits in its own small black plastic housing,
This housing is tie-wrapped into a plastic moulded compartment just behind the L/H door (UK passenger side)
There is a drain hole in the bottom of the compartment, which can become blocked. The compartment will eventually fill with water, from rain and/or washing. and the water then spills into the motor housing.
The problem is this.
Imagine you have a bucket with a drain hole, (that is the plastic compartment behind the door).
Put a cup inside your nice dry bucket, (the cup is the motor housing)
Now put a motor into the cup
If you now plug the drain hole and start filling the bucket with water, eventually the level reaches the top of the cup, and the cup also fills with water.
Now unblock your drain hole and the bucket empties, but the cup does not.
No amount of further unblocking and keeping the drain hole clear will empty the cup, and that is exactly what happens to the Z4 motor, as it sits and slowly rusts away whilst remaining submerged. And it only has to fill once.
So here is the (second) way I did it: (other methods are available.... =)))
I know! I removed a roof once to do this on a previous Z4.
First job is to remove the parcel shelf.
To do this, squeeze together and push upwards the plastic clips. There are two on each side of the parcel shelf:
The clips will probably fall down the sides, but you can get them later,
Pull the fabric flap off the shelf:
Now pull each hinge upper plate away from the parcel shelf towards the centre of the boot:
this is best done with the parcel shelf in the upper position
Remove the parcel shelf by moving it towards the drivers side as far as it can go, and pulling the other end out. Then you can rescue any clips that you pinged off earlier.
Now you can remove the complete LHS hinge assembly for the parcel shelf.
Remove the Torx bolt at the front, and the bolt at the back.
There is also a rivet, in the now viewable plastic well.
Pull the centre of the rivet out with some pliers, and then remove the outer washer:
Now give the whole hinge assembly a good pull towards the middle of the car to remove it. A little hump shape underneath it provides some resistance, but otherwise it just needs a bit of effort.
Now you can see all the way into the well and behind the door latch is the dreaded motor in its housing:
cut the tie wraps to release the hoses
By lying on my back in the boot with both arms above my head and through into the compartment I was able to wiggle the housing about.
It is held in place by two tie wraps around the ram which is nearest the door, and on the RHS of the housing. But I could not get it to shift. I even tried from the door end but that was worse and just wasted time taking off the plastic cover and speaker compartments behind the seat. None of that is needed by the way, Everything can be done from the boot.
So what I eventually ended up doing was separating the motor housing,
The housing comes in two parts (see later photo's). It is held together with some black fabric tape.
I was able to pick at the tape and pull a lot of it off. Then with a long bar I was able to separate the top of the housing from the tie wrapped bottom section exposing the pump.
From then on I could pull out the pump/motor assembly, and finally wrench the bottom of the housing out.
The motor was soaked and rusty,
and the bottom housing was full of the dirtiest water imaginable, that could run down my face as I tipped it up in the boot over myself.....!
With the motor pulled into the boot you can see the ram and associated hoses to it, Try not to pull too hard on these:
Now you can see (with a camera) the bottom of the plastic well and the drain hole. Note the rusty water tide mark:
The housing looks as follows, with the tiewraps on the plastic fin which breaks away eventually:
You can see the remainder of the fabric tape that I couldnt get too
and inside is the sound proofing which stays soaked:
You can separate the motor from the pump by removing 2 allen bolts, but do this with the pump downwards and break the joint nearest the motor or you will lose hydraulic oil (ask me how I know)
With a quick wipe down and wire brush, I then sprayed WD40 all over it and inside it. then connected to a 12v power supply and it immediately came back to life so I ran it in both directions whilst still oiling it.
Sorry no pictures for that.
After putting it back together and topping up with hydraulic jack oil through the little plug in the top of the pump. (check level with roof down) I was able to get the roof up and down fully with no noises,
To operate the roof you have to temporarily press in the parcelshelf position microswitch (i used a 12mm socket for that):
The hoses that now go to the motor have to be routed across the plastic well and below the hinge. This involved cutting the plastic away and securing as follows:
The hinge assembly had to have the same treatment before being refitted:
Then time to rebuild:
I pulled out the LHS carpet from the side of the boot to be able to locate the motor.
I tiewrapped the dried out soundproofing around the motor and tied it to a little connector block which is under the LHS side carpet:
Keeping the motor underneath and the pump uppermost:
Then just wrap the carpet back around,
refit the parcel shelf and fiddly clips, and finally the fabric flap.
and most importantly have a beer, knowing that it will no longer get wet, It is easy to get to, and top up if required.
Over 2 grand to fix from BMW,
I did it for free.
Thanks for the detailed procedures and step by step instructions.
I now have a working roof, having cleaned and oiled my motor. Extracted it yesterday. Ran a bit rough but an oil and overnight rest helped. Reinstalled in boot but putting back the parcel shelf has driven me to drink. lol. Main task done though. The manual override valve had also seized up so had to free that up too. As others have said BMW, why there?? Probably so they cn charge you a fortune to fix a waterlogged motor. Cheers. Paul
Hodgetts
Thanks for all the info. Had a failed motor for top on my new 2006 Z4M roadster. Used your method, took 6 hrs but got it out via trunk ( upside down and contorted!) Only problem was cut 3 of 4 hoses. I can reconnect with a good quality splice but don’t know which hose goes to which of the 3 remaining terminals. I may be able to tell by length of the hoses that may match up. Sprayed heavily wth wd40 and working now. The motor casing was dry as I live in Hawaii and not much rain or road junk.Cut power also but I think I can reverse polarity if switch is backwards.
will relocate to trunk. I would recommend to anyone trying this to use a 12v Dremel and cut top off casing rather than tin snips! Maybe use a long sharp hacksaw blade to get to wire ties at left bottom of plastic “cup”. Thanks again, and if any advice on hose placement would be icing on the cake!
Hodgetts
It's happening all the time with my photos now. I have stopped updating my journal now as there is no point. I also keep getting a message saying '404 access denied' to the forum. Wouldn't mind but it costs me to host pictures on Flikr for here and they don't show up reliably anymore
rsutoratosu
Anyone ever refurb the Pump side ? Since mine rusted out I have a mustang pump/motor in there now. But since I already bought an ebay motor, I figure ill get the original pump working and hook it up to the ebay motor as a spare.
I have read that there might be some valve issues or the bowden button issue, is that something a DIY can repair or just not worth it ?
Bigbazzaaa
4 hours and lots of expletives later I finally got the damn thing out thanks for the guide. Worst bit was getting the bottom half out. You must have the strength of Samson as took me forever. Just to put it all back together but raining today so it can wait. Only hing missing is to ensure no children are in the vicinity so they don’t hear you swearing at the crazy German designer who put it there on the plans lol
Andrew Polasek
H did you cut the hydraulic hoses? Let us know if you get the splices to work but those hoses are under high pressure during operation.
R I don't think that pump is serviceable, as you know the oem BMW unit has the relief valve built in and they do have a nasty habit of sticking in if the release cable was pulled for any length of time. The Mustang pump solves that issue by not having one. ;)
Edit: Sorry guys-- I see your posts were from several months ago, reckon you got it figured out by now..
kevver
I've just taken my motor out and it was jammed solid. Although i managed to turn it eventually with wd40, it was still no go.
I ordered a new motor but in the meantime decided to try and pull my motor apart.(google "how to take apart a 12 volt motor")
After taking apart and giving it a good scrape and clean, hey presto it works! These motors are very robust but very simple. No need to buy a refurbed motor as you can easily do it yourself. I now have a spare motor arriving through the post which i no longer need.
Years ago we changed a door window lift motor on a Talbot Solara but it didn't fix the problem. Then I had another issue, trying to get the old one replaced under warranty. We tried various ways to burn out , bugger up the old motor but it was indestructible.
myrddin
Question... I am working on my sons Z4 and with the help from you folks and others I was able to get the pump working... for us it was just the manual bypass was stuck in... I sprayed it with some lube and worked it in and out... I can pull it out and the top works... still trying to get it so its reliable to use as the bypass valve... if I cant trust it Ill just leave the cable off.
I need help... you folks seem to be the experts :)
1. In my case I removed the top because I couldn't un plug the drain funnel on both sides... once I removed the top I found a lot of rubbery things (looks like its coming from inside the headliner) stuck in the drain... also I think there was some butyl in the drain as well. I tried wire, pressure washer and was unable to get it unclogged... so I ran a 1/2 inch drill bit down the drain till it hit a metal object (then I stopped) at that point all the water drained out and continues to do so... I did see some water drain out under the driver side door (on the chassis where the frame part has water drain holes) is this normal? I am not real impressed with this design... I wasn't real excited about running the drill in... but it is draining... Thoughts?
2. I want to relocate the pump to the trunk and place it under the trunk carpet on the left side. I cant tell for sure where you folks are drilling through to get the pump and lines into the trunk area. I would assume its in the back corner and you just drill into the upper drain funnel area? And is it OK to disconnect the hoses to run them through a hole.. or I see some make a hole and cut it to the side so they can just maneuver the lines into that hole and then into the trunk. Any picks or comments would be great.. I want it to look like a factory install, verses an after thought... hope you can help.
3. When I put the top back on, should I spray silicone into the weather stripping channel so the rubber will seat into the groove? Or should I do something else? In the past I used dish soap for old windshield gaskets because it dries sticky and will not allow it to slip back out... not sure about the lube... thoughts?
please share some pics with me... I plan on doing this today... as of now my game plan is to just drill a one inch hole in the upper drain funnel and guide the lines under the shelf hinge (not cutting the hinge). Id like to make a bracket to secure the pump to the wall and then cover up with the side carpet so its hidden. I also plan to reuse the sound insulation around the pump. And for the top I am leaning towards not using the lube... unless I cant get some of it to go in the channel but I am not really sure.
You don’t need to drill any holes to locate the pump into the boot (sorry, trunk.;)). I’ll take some pictures after tea for you.
