Z4 Radio Problems
Brian Kaplan
Hello!
My 2004 Z4 radio went dead after I tried to put a CD in. I was able to get the CD out, but the system is still shut down. Checked fuses to radio and CD, all OK. Suggestions?
Hi Brian, did the head unit eject the CD normally or did you use other means ? The headuheadunit is fairly easy to remove on the E85.
If you look at my progress thread called "My Z4 . . . . . . . My way" it is detailed in there.
Brian Kaplan
Hi Tony!
No it did not eject normally. I had to pull the CD out with tweezers. No power to the system...
I would remove the unit and check the connections if it were me then Brian. As I said , easy enough. I can post a link to my progress thread later when I'm home from work.
Brian Kaplan
Thanks! I will let you know what happens. I heard there is a fuse on the radio itself too that could be blown.
I believe there is Brian.
