Z4 E85 boot spoiler
Antm72
South Yorkshire
Tiger seal will definatly do it it comes in 3 colours i think, white, black and grey used to use it to bond body kits to mk3 escort turbo's very strong when bonded to the point the part would break before the tiger seal would let go! It is brought in mastic tubes great stuff , stuck it on smooth it like sealing a bath and leave it to bond.
The spoilers on the T5 are bonded on, they use a product called tiger seal upol.
That's the one I'll be using I'm pretty sure.
Cheers for that Ant, you may just have talked yourself into a job bud!:)
So, having decided on what needs adding to the rear end, here's what I think needs adding to the front.
http://www.ebay.co.uk/itm/front-und...017667?hash=item1e980d2703:g:YusAAOSwk5FUsLmY
Cup spoiler front spoiler BMW Z4 E85/E86 ##Cupspoilerlippe suitable for BMW Z4 E85/E86 built 2002-2006 #passend for all models, except M/M package #Sportliche optics and integrated rear underrun protection for your original bumper #Wird bolted to the original bumper and glued, supplied mounting material #Mit vehicle-specific parts certificate. But good fit, since no universal part specifically designed for this type of vehicle!
##Cupspoilerlippe is made of high quality material ABS and provided with a structured (grooved) surface, so the lip spoiler is very resilient to scratches #Durch the textured surface is optically no painting necessary! Of course, the surface structure allows still painting (product is clear) ##Material is flexible #Mit Assembly instructions.
Thank the lord for Google Translate.
The cave could be a busy place this spring!
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Be careful you don't lower the front to near the road tony, my E85 sport was so low I had to crawl over speed bumps in order not to catch the front bumper. Damn annoying!!
Mike
Good point Mike, I will ask the German makers for any measurements sitting on standard sport suspension then.:)
