- Joined
- Feb 18, 2016
- Points
- 231
- Model of Z
- Z3M Imola and Z4 (e89)
OK
your getting no increase in power at the ist stage and second stage of the Vanos, or is it just less noticeable? When the Vanos is working correctly the sudden surges in power are less obvious as the engine should be performing better from idle right through to the red line. When its in need of a refurb (other than any rattles) you will find the low end and mid performance delivery is affected and the two stages of the Vanos are very noticeable as its is delivering extra power just at thoise times in the rev range.
I now don't get the real kick from the vanos since it was rebuilt but the power overall is far better with increased performance from idle to 3000 than before and from 3000 to 5000 than before but I still notice a small surge. So are you saying you aren't getting as much of a kick from the vanos or is the overall power down on the car? Because if the overall performance is better and the kick from the Vanos is calmer than before thats correct? Does that make sense?
