Z3 Road Horn.
Is the Z3 supposed to have a double horn application? My sounds embarrassingly ridiculous as in Nody like :( Mine just has the one having checked.
Thanks.
Ianmc
New Forest
Z3 (M44)
Can you still buy horns that play a tune; that would be cool!!:)
Maybole , South Ayrshire
@andyglym just went out in the rain to have a look there is one horn on either side in the same location.
On mine you can see them if you look down directly behind the headlight you should be able to see it down behind the bumper.
Only if they’re your one and only horn. Multiple tone horns are all illegal though. Mine were La Cucaracha!
Bampz
Pembrokeshire
I used to have air horns on my Capri years ago used to play the general lee tune , worked off a separate switch , sounded great especially going under railway bridges , (got me thinking now )
Bampz
Pembrokeshire
Tony ,I thought there was an age limit on what year car you could fit them , not sure though
Thanks mate, just the one sounder, I'll look into it :thumbsup:
Yep, same as mine. They were on a Mini Clubman Est.., a 72 Capri, a Mk.1 Consul (Granada) and lastly a Chrysler Alpine and they were a blast under the local rail bridge before they took it down. I had a long pair of single tone ones on my Euros too.
Yes @t-tony I should have said that :oops::oops:.
As your main horn ie the factory one no multiple tones ,bells,gongs or sirens allowed for mot.
Now if you wire up things like that separately that becomes between you and the local constabulary :D:D
Cheers chaps, just after the standard spec. Ashamed to use mine less I get my Man Card confiscated :(
Andy work out which side is working take multiplug off not working side put multi meter or test light check for power ( more than likely the horn failed both run from same initial wiring so if one working other should have power)
Sounds like by what your saying you needs a low tone
Yeah, you need a Barry White cos it sounds like Tiny Tim is singing;)=))
I've only got the one sounder fitted mate, need another then?
BillyB
Edinburgh
2.8 Individual Roadster
Oh! it,s a technical query I misunderstood the title, I thought you were really happy with your road trip the other day.:whistle:
Shine a torch down each side should be able to see them both from the top
