Is the Z3 supposed to have a double horn application? My sounds embarrassingly ridiculous as in Nody like
Mine just has the one having checked.
Thanks.
Thanks.
Mot fail.Can you still buy horns that play a tune; that would be cool!!![]()
Tony ,I thought there was an age limit on what year car you could fit them , not sure thoughOnly if they’re your one and only horn. Multiple tone horns are all illegal though. Mine were La Cucaracha!
Thanks mate, just the one sounder, I'll look into it@andyglym just went out in the rain to have a look there is one horn on either side in the same location.
On mine you can see them if you look down directly behind the headlight you should be able to see it down behind the bumper.
Cheers chaps, just after the standard spec. Ashamed to use mine less I get my Man Card confiscatedYes @t-tony I should have said that.
As your main horn ie the factory one no multiple tones ,bells,gongs or sirens allowed for mot.
Now if you wire up things like that separately that becomes between you and the local constabulary![]()
Andy work out which side is working take multiplug off not working side put multi meter or test light check for power ( more than likely the horn failed both run from same initial wiring so if one working other should have power)Thanks mate, just the one sounder, I'll look into it![]()
I've only got the one sounder fitted mate, need another then?Andy work out which side is working take multiplug off not working side put multi meter or test light check for power ( more than likely the horn failed both run from same initial wiring so if one working other should have power)
Sounds like by what your saying you needs a low tone
Have you looked both sidesI've only got the one sounder fitted mate, need another then?
I'll take another look but certain I anly saw one sounder. Thanks mateView attachment 142567 View attachment 142569
Have you looked both sidesView attachment 142561 View attachment 142563
