- Joined
- Aug 2, 2023
- Points
- 66
Hi y'all! My 1998 Z3 passenger side window is a bit erratic; it wants to close upwards at an angle, usually the front goes higher than the rear, and sticks until straightened, by dropping it slightly until it frees up and winds straight up again. It also seems to drop on one side more quickly than the other so again goes at an angle until it sticks. Is it worn parts, or does it just needs a good clean and lubrication of the runners?
I've also noticed the driver's side window doesn't seal as well as it used to against the hood, so leaves a very small gap and drips get in - it there any possible adjustment?
