Z3 EV Conversion
Andybpowell
Norfolk
105Kw ev
In all honesty I can't argue with you I just liked the simplicity of my way keeping it all in one place but logically having a permanent live cable running under the car is not Ideal even if it is fused
So this is one of the reasons I'm posting all of this so someone can talk me out of doing things that seem like a good idea at the time sometimes I can be a bit focused and not see the big picture 😁
Tom Cheesewright
Manchester, UK
Ha! It is a ballache but I'm hoping to reuse the old S-box at the remote end and I've built some extra contactors into my junction box for the inbound side. That's the bit I forgot initially: of course you have to isolate it at both ends.
Andybpowell
Norfolk
105Kw ev
This is the revised front battery box just containing the contactors for the front battery instead of front and rear, I've fittted a perspex cover over the premanent live parts to improve safety the BMS is fitted, the can bus current sensor is fitted and it also now has a connection block for the rear battery box and the charger to connect
and most importantly it's in the car :party:
I do have a slight issue with the brake booster pump being in the way but that's pretty minor
Tom Cheesewright
Manchester, UK
Looking good!
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
So will the connection between the rear box and front box be live when the 12v is off?
Why is permant live a problem? When the car is 'off' and stationary then damage or movement to the underside is unlikely. Any damage is going to happen, if ever, when the car is 'on' and moving?
Mind you. I don't know what I'm talking about so don't listen to me.
Andybpowell
Norfolk
105Kw ev
You're correct in what you say but it's more about good practice, also if they decide to regulate such conversions at some point then it might become more so doesn't hurt anything other than my OCD to do it.
Tom Cheesewright
Manchester, UK
It's more about working on it - you, a mechanic or (worst case) emergency services. It's good to know that - barring contactors welding closed - if the key is out, there's no HV floating around.
Duncodin
M44 FrankenZed
That's it. I have no idea how high HV is. If it's squillions of volts/amps then I'd also be wanting it off most of the time as well. Like I said. I don't know what I'm talking about - but eager, and quick, to learn.
This thread just blows me away .............. incredible. :thumbsup:
Tom Cheesewright
Manchester, UK
Typically around 400V and potentially a few hundred amps. It's toast territory!
Ianmc
New Forest
Z3 (M44)
Assume you need a HV "ticket" to install such?
Nope. Not yet. I suspect there will be tighter regulation in the years ahead but it's a bit of a wild west at the moment.
Regulation will come when an MOT tester gets electrocuted;) In the end you don’t have to be a time served plumber to fit a tap washer, but maybe some should.=))
Tom Cheesewright
Manchester, UK
I'd actually like there to be a bit more regulation, like an enhanced MOT for example. Doesn't need a full IVA for a simple motor swap, but some safety checks on the HV and mounting would be sensible.
The consequences of none SQEP HV installation are rather more severe. :(
[/QUOTE]
My remarks were ”tongue in cheek” I thought you might have realised?
For an ICE conversion when it comes to an MOT the tester is required to make sure it has been done correctly but as of now Testers don’t have enough knowledge or training to be able to make those type of decisions on an Electric Motor conversion, so personally I think an SVA test would be sensible.
Andybpowell
Norfolk
105Kw ev
It's been nearly a couple of weeks since my last update and the car doesn't look much differant but like lots of car projects a lot of the time and effort is buried away in it's innards
all of the High Voltage wiring is complete
the low voltage wiring is all in place and just needs connecting ( just 🤣 ) I've made a mounting plate up to go where the ecu went which has the three main boards on it this is two of them
and this is the third which I've just remade to incorporate some things I hadn't thought of
this final board is the only one which will be powered permanently this will monitor the charging socket, ignition live and contactors and decide what needs to be powered up it also controls the power to the switched live relay,power steering relay and coolant pump using PWM control where possible to reduce power consumption
