They are quirky little thingHad the same problem a couple of years ago - dash lights wouldn’t come on. Got into the car the next morning and all was fine - and still is.
Got this issue on the Imola M I'm rebuilding, temp, fuel works but don,t fully register, rev wont work, speed is fine, I'm not getting any code up. Last time it went iffy all was well when it was started then went Pete Tong, fuel and temp readings dropped and rev counter stopped working.If you get EEP_2 you may also find that the fuel gauge, rev counter, odometer, and temperature gauge don't work but the speedo does. Eventually you'll probably need a replacement coding plug as I did.
