For Sale Z3 Aftermarket Hardtop fitting brackets 4mm steel CNC'd
I'm starting to make z3 hardtop fitting kits, each sale will help fund my own Z3 restoration.
Each kit is CNC'd from 4mm thick steel and hand welded, and finished in satin black spray paint. These are supplied with an aluminium 'turret', but not nuts or bolts.
2x M8 15mm Bolts are required to fit the bracket to the body and you will also need the front fitting bolts that pass through the hardtop and bolt into the front screen. These bolts are available from BMW direct or bought online, but are not supplied. Full fitting instructions are also found online.
There is a 7-10 day lead time for these brackets which are made to order.
Currently available on eBay - if this advert expires, please contact me direct to see if I have any in stock. https://ebay.us/m/AdqhA3
Happy to post worldwide - these kits have already gone as far as USA and Australia!
Not needed for me but have to say they look well engineered. Can you add a price for as well to your post to save a lot of enquiries.
Thanks for the positive feedback. I've put a lot of effort in making these as well made as possible. Ok, they may not be OEM, but for my own hardtop, they are as good as
I've added tbe eBay link above.
Thanks
wow very impressive! As an apprentice machinist myself I must say, I thought about doing this complex job myself but it looks like you've nailed it! Looks great, I will keep this in mind for sure.
