Z3 1.9 Won't start
Hasel5
Morning all drove the car to work stopped to check tyre pressure and then would not star
New Battery so not that
but do have a leak so drivers four pan wet
Dash lights up all electric and lights work etc just not turning over
Is there a module under drivers seat that could be wet and not allowing to start
Its a 1.9 manual 1998 Model
Thanks in advance
bmwz3tower
There's nothing under the floor that could wet which would cause it not to start. How far had you driven before you stopped to check pressures?
ChrisD
Vale of Evesham
M44
Thanks in advance
If you’ve recently had a new battery check the battery terminals are still good and tight. Loose terminals will allow everything to look ok except when you try to draw heavy current when trying to crank. Go for the easy stuff first.
Hasel5
Quick update car bump started fine so either ignition switch or starter motor
Hasel5
Quick update car has dried out and now starts as should carpets were soaked
going to chance a run out in it
