David Cullen Zorg Legend Supporter The M44 Massive Joined Jul 8, 2014 Points 76 Location Prosperous, County Kildare Aug 31, 2014 #21 thanks Tony, it actually works very well indeed and is solid with a better fixing, cant see it breaking again to be honest
mrtikle Regular Member Joined Aug 23, 2014 Points 13 Sep 20, 2014 #22 What do you use to lube the runners? Doing mine today
David Cullen Zorg Legend Supporter The M44 Massive Joined Jul 8, 2014 Points 76 Location Prosperous, County Kildare Sep 20, 2014 #23 any grease will do it to be honest, it not high speed or temp so even just a spray of WD40 would keep it going for a good while
mrtikle Regular Member Joined Aug 23, 2014 Points 13 Sep 20, 2014 #24 Cheers mate in halfords right now so timing couldn't be better
David Cullen Zorg Legend Supporter The M44 Massive Joined Jul 8, 2014 Points 76 Location Prosperous, County Kildare Sep 20, 2014 #25 lol and for those watching, my little trick is still working and is 100% trouble free ;-)
oldcarman Zorg Guru (V) Supporter Canadian Zeds The M44 Massive Joined Feb 11, 2014 Points 188 Location Pine Falls Manitoba can. Model of Z 1.9 M44 Sep 20, 2014 #26 mrtikle said: What do you use to lube the runners? Doing mine today Click to expand... BMG USES SOAP ON A ROPE!!
David Cullen Zorg Legend Supporter The M44 Massive Joined Jul 8, 2014 Points 76 Location Prosperous, County Kildare Sep 20, 2014 #28 anything that is not too heavy, KY jelly if you have to
