I have been having problems with my window, first off the guide rail was coming off the window itself, I fixed it with some tec 7 )) thought that might do the job but it didn't, the window was getting stuck, if I put small pressure on the top of the glass it would move a bit better going down, no problems going up..... so after some more investigating I found that the reg was held on in the middle via a stupid mount and nut, the metal its held to is crap and over time seems to have ripped its way out of the bracket, there is no fix with using this mount as the metal bracket is torn so I am going to make up a stronger bracket and use a few self tappers etc to fix the reg back to where it should be, will have pics of the fix up when it is done, here are some pics of the issue at hand ;-/ has anyone tried to fix this before? the motor is perfect and strong by the way so I don't want to get a new reg, and even if I did the mounting bracket is fooooked
fix with the tec7 ;-)
ripped reg and you cant see the bracket but its behind the screw hole
this is the stupid design rivet bolt that tore its way off its bracket grrr
so stay tuned to see how this can be fixed
