Will Z3M coupe wheels fit
Zephyr
My pathetic facelift Z3 2001- 1.9 model?
Its a widebody (all the facelifts are) but I am not sure if the axles and the rest stuff are conpatible…
I can not try them on, they are located in Germany….
has anyone any solid info? The seller has no clue at all.
Zephyr
Btw, arent they supposed to be stamped? With some letters etc?
Z4 MR
After 5 months membership??
Way off topic, but there is criteria based on participation but not just post count or length of membership. If you go to your profile page you’ll see the “trophies” awarded while interacting on the site.
Ahlah69
Cool thanks guys… I thought the Guru was knowledge…. M’s have shorter axels and arms to fit wider wheels
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
@Zephyr From memory, Z3M rear wheels wont fit due to the offset. The fronts will fit both front and rear axles so if you can find 4 x front wheels you should be OK. These's at least one forum member that has them on his non M car
Zephyr
Thanks guys. You saved me from a lot of trouble. I was ready to buy them. Will not go the four fronts way, I like my staggered deep lip ones better than four shallow ones. Cheers.
Dont the 1.9s have the same short arms and shafts as the M or is that just on the pre-face lift models?
Zephyr
According to the “bible” my car has the same shafts as the 2.0.
