The beams are all the same on the Z3 (Not including Z3M) So you can pick a second hand one up.Reason for asking is I want to refresh the subframe so thought of picking one up secondhand to reduce the time it will be off the road.
No, it fits only the E36 compact, all other 3 series models have completely different rear beams.According to realoem my 2.2 takes this, which fits allsorts of e36s.
Really it needs your last 7 to do a cross-check.
And if you follow the clicky link thing you'll come toNo, it fits only the E36 compact, all other 3 series models have completely different rear beams.
There are various trailing arms as well, depending on facelift / pre facelift / 4 or 6 cylinders.
