Whining Noise On Full Lock
Mick
Manchester
Hi All,
Has anyone had a whining noise on full lock, and how to resolve? I think it is the PS pump overloading? Just wondered if anyone had encountered before I get my hands dirty....
Z3 Roadster - 2.2 (2002)
Thanks in advance
Macca
Wisbech St. Mary
2.5l Msport
Hi All,
Thanks in advance
Yup, it's the pump loading up. I had it on my Z3.
Brian4
Near Grantham
Z3 3.0i Auto
I would check the fluid level as well. My daughter had it on her TT and the fluid was low.
jonco
Chester
'98 1.9 Auto
Hi - if you hold the wheel against the full lock stop it will whine as it is overloaded and can damage the hydraulics - when you relax the pressure on the wheel it should stop. Check fluid level just in case.
Titan
Moderator
North North Yorkshire
sDrive35i
Hi - if you hold the wheel against the full lock stop it will whine as it is overloaded and can damage the hydraulics - when you relax the pressure on the wheel it should if you stop. Check fluid level just in case.
+1
All Z3s do this but only when the full lock limit is reached. This is normal.
Mick
Manchester
Hi All,
Thanks for the advice. I topped up the oil and it helped, but I think I will change the reservoir as the filter may be clogged (looks original). Had a look on-line and found a billett version, but not sure if this is the best option or just a straight swap?
Anyone bought a reservoir? Can you recommend a stockist?
Kind regards
Mick
jonco
Chester
'98 1.9 Auto
Why not just change fluid (it's probably original) - inexpensive and fairly straightforward. Did it recently on my `98 1.9 as a precaution and it does sound better or maybe it's all in the mind.;)
B
bonzo
Guest
I sometimes get a whining sound whatever position the steering is in.
I eventually traced it to my wife! ( boom-tish )
ticklemejoviemo
there should be poppet valves to prevent damage at full lock, pressure relief
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
Z
zedonist
Guest
When I bought mine there was a whining noise turning the wheel, but the process was also laboured, it turned out to be a new steering pump required, at no cost mind, but as mentioned earlier all cars whine on full lock........but should not whine constantly...
