Which oil ??
Ifan Evans
Hi all,, I was wondering which oil you put in your z3? What's the difference between 5w30 and 5w40 ? I've a 2.0 2000 model. Anyone used that Home Bargains oil, seems like a bargain ...
Devon Z
Brixham, Devon
99 2.0 Individual
Home Bargains oil I think is only semi synthetic 10/40? You'll need fully synth, I use 5w40 Triple QX from Euro car parts they always have an offer on oil and filters I think it's 35/40% at the moment, I use a Mann oil filter comes with a sump plug washer and filter housing seal, I would also replace the two small O rings on the base of the filter housing, I do them every other year they are a dealer part.
I'd look at doing the gearbox and diff oil as well as its not on the service schedule BMW think it should last the life of the car!
abh29
North Wales
Z3 2.2 Sports
I changed Engine oil,gearbox oil and diff oil in the last few month, got them delivered from Opie oil,top quality oils at reasonable prices,oil was Shell Helix Ultra 5w-40
The oil filter came from BMW and I think all washers came it , I had included the washers from Opie,so had spares
It has really improved the gear change,
I consider the term "sealed for life" means until the part packs up because the oil is worn out.
Ifan Evans
Taz Horton
Cambridge
It's up to you but cheap oil usually means just that . Oil is made up of addetives which are expensive and the company put them in to bring it into specification so a cheap oil will in effect run out of specification much quicker than a premium oil , if that makes sense . It's the life blood of your z ,, I personally don't drink tesco own brand lager if you catch my drift :thumbsup:
Ifan Evans
Good point. Think ile have a look at autoparts ,,,cheers
Bringit96
London
Ifan Evans
Does anyone know the recommended oil for the 2ltr ? The owners manual didn't come with the car
abh29
North Wales
Z3 2.2 Sports
Suggest you contact Opie Oil ,refer to the .org discount.
Email him with your vin number
abh29
North Wales
Z3 2.2 Sports
As regards having no handbook,try one of the forum residents who at times dismantle car,one of them normally can assist.
