Which battery
Norm44
Locks Heath Hampshire UK
This is what I went for mate
Norm44
Hi my Bosch S5008 Battery fits in the space but does not allow for the long bolt and clamp to retain it
I have fitted the battery into the back retaining location and held on place with a wedge of rubber at the other end.
Hope this helps
Norm
UPDATE*********
Now found that the original bolt for clamp was sheared off so drilled and tapped thread and fitted new bolt and clamp
Norm
ATM
Fife
1.9 M44 narrow
Thanks bombur. I just bit the bullet and bought the Bosch S4 and it does fit. The old yuasa was 248 but this works fine
ATM
Fife
1.9 M44 narrow
Thanks Norm and Ant too. Well I did manage to slip it under the fixed retaining bracket at the front end and then get the rear clamp I place too and pin into the rearmost drilled hole, so should stay put ok now. Hopefully useful info for others in future
jaguartvr
It may be a moulding but it looks as if transit plugs sre still in place on AntStark's battery
