Wheels
Antm72
South Yorkshire
Can i fit an 8j rim all round on my zed? offset is fine at 40 i presume i can with out any issue at all ?
I run a staggered set at the mo so i know the rear will be fine but will an 8j rim on the front be ok ?
I run 8.5" ET41 all round, so an 8" ET40 will fit fine on the front, but you will probably want some spacers on the rear.
Really useful tool for working out the difference between your current wheels and your desired set. This tells you the difference in how the wheel will sit - either further in or out from it's current position.
http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
I recently found this site and find it a little easier to understand the differences between two wheel sizes
www.willtheyfit.com
Gives a nice little diagram and other specs too. :)
Cheers guys will take alook staying at 17's i think and then will drop it on coilovers to get the right stance.
