Wheel Spacers yeah baby
windym
So after getting the 108,s from @Lee I decided to space them out, tricky to measure but decided to squeeze 15mm front and back.
Was not holding out much hope for the front and figured the rear would look great, how wrong I was the 15mm fronts were fine the 15mm rear were still lost. Anyway ordered some 20mm for the rear for Friday so some pics.
Just got away with it I think so now to lower by 30mm, I will put one pair of spacers up in classifieds soon along with Lee,s shiny nuts.
Andy
Looks so much better. I put 10mm on the front with mine and 20mm rear. Get those springs ordered and pop round :)
Most defiantly I still owe you guys a breakfast.
Andy
I had 12mm on the front and 20mm on the rear on my Z3 and now they're on my Z4 with the 108's Andy @windym and they're bang on. Look forwards to seeing yours with some new springs mate.
If say hold off opening the 20mm until you lower the suspension.
As you lower the tops of the rears go inwards noticeably affecting how much spacer you want and may need a bit more say 25mm.
On my 17's style 32's I could easily run a 30mm.
Not sure if the front camber is similairly affected but if it is I think it's much less pronounced than the rear.
Got round to putting on the new 20mm rear spacers today, they make a noticeable difference over the 15mm. It is quite deceptive what an extra 5mm does, the wheels now sit where I want them too, so just lowering now.
Yep - the desired stance is nearly there! Looking good!
