When I looked on Autodata it said 110 - 120 nm and I opted for the higher figure, without spacers I ran at 110.Thanks Tony, that's tight![]()
Looking forward to seeing the effect they'll have when you've got them fittedThey're here. Arrived too late to put on today so I'll be fitting them in the morning
.Without that click it just wouldn't be safeMine are just arm tight, however I do make a little click with my tongue when its tight enough.![]()
Aint that the truth, wouldn't drive without it, I once forgot so had to drive back and redo them.Without that click it just wouldn't be safe![]()
Am I going to tight then Gary?The point I'm making is if the bolts are grade 8.8 or 9.8, anything over 90nm will stretch the threads. You wont notice until one fails. If they are grade 10.9 then 120nm is fine.
.Yes, fitted them in the morning and it would have been rude not to go out to check them. Didn't get time to put photos up before we went out for the evening. I'll put them up laterCome on @Minty where's the pics of them fitted on your zed ??
I know you fitted them this morning and you're still out on a test drive.
Naughty Mr Mint
oops, cat out of bag![]()
