Not really, you have 5 holding the spacers to the car (hub) and 5 holding the wheel to the spacer as you've introduced another joint face.
Loosing a wheel is critical no matter where you areThere's my point exactly Brian, you have to torque the wheel bolts correctly. So now you leave them on all the time, is that because you feel that they will be ok or that in a track environment it's not so critical if you loose a wheel? I assume that when you say you see stacked spacers up and down the pit lane, that means people still take them off because they don't trust them either, but then they're happy to trust them on normal roads.
Oh, sorry, I see what you mean. Using composite spacers isn't on my list of good ideas. If you need 10mm you need to fit a. 10mm spacers not 2 x 5mm.Loosing a wheel is critical no matter where you are, I guess I was trying to say I have never had any issues on track with them so I leave them on.
By stacked spacers I mean 2 x 5mm = a 10mm spacer or 2 x 5mm + 2 mm = 12mm...........![]()
I agree with what you're saying Pete, but your wheel is still only attached to the spacer, not to the car. The spacer itself is only attached to the car not the wheel. Also you surely can't use that type if you only needed, say, 10mm spacing as there wouldn't be enough hold for threads or to hold a bolt head from the rear side l don't think. Just a difference of opinion, I'll stick with what I trust.same amount of joint faces as the bolt though type with double the amount of bolts. That is what I am comparing with, not versus a non-spacer setup
ps. A fellow Avenger owner, 2 actually.![]()
I admit to some of the above Pete.yes, but did you jack the back end up, add a plastic grill to the rear window, with a Raydot stick on heated rear window element, fake sheepskin over-the-seat-back headrests. cut the front bumper so that they were only at the corners and add a square front numberplate, then wire some aftermarket rear foglights up as brake lights, fit a pioneer radio cassette with a graphic equaliser/ booster and spark rite electronic ignition and an electric washer pump and airhorns and a holographic 'avenger' sticker? Oh and two Cibie Oscars
God I still do this sort of stuff now,.... 40 years later (hopefully toned down a bit)
1st. one was a 1973/4 1300 GL 2dr maroon red (can't remember the name) with a white vynil roof from front of roof to about 1ft from rear windscreen.2n. one was 1977 1600LS 4dr met blue with black rag top. I worked at a Chrysler garage.
