Wheel nut torque value
Z4 MR
Hi,
Finally got around to buying a torque wrench for correct wheel refitting ;) . What torque setting should I dial in on this for wheel nuts?
Is it a standard setting for all wheels nuts, as I will be taking the MINI's wheels off soon too.
Thanks all
Boysie
West Chiltington, West Sussex
M Roadster S50
People dont realise the importance of a proper torqued nut
The amount of times i have seen cars and van wheel
nut fitted with just a air wrench, in fitting bays.
Last year we had a wheel come off the caravan,
"Not a good experience"
I would imagine that every nut on the car has a torque
setting,
Ask most people most a torque wrench is :-? #-o
DangerousDave
There are only two nuts I use a torque wrench on - wheel nuts and cylinder head nuts. Most other nuts can be done by feel and common sense.
Torque wrenches should be calibrated. A new one should be OK, but older ones should be checked. I made a tool using some bar and a spring balance. It does the job :) .
Z4 MR
Thanks Ardchyle :-bd
E30 / E31 / E32 / E34 / E36 / E38 / E39 / E46 / E52 / E60 / E61 / E63 / E64 / E85 / E86 = 120 ± 10 Nm
Looks to be a 'one setting suits all' value. Nice and simple for a change.
Boysie
M Roadster S50
I dont want to put a spanner in the works
To much torquing on here :D :D
Titan
Moderator
North North Yorkshire
sDrive35i
Careless torque costs lives
Z3nt from m'iPhone on Tapatalk
Boysie
M Roadster S50
torque of the devil and he appears :D :D
Titan
Moderator
sDrive35i
Now I have had chance to check the Owners Manual (2001 version for Z3 1.9i, 2.2i, and 3.0i) page 156 says
100 Nm or
74 ft.lbs
DangerousDave
130Nm compared to 100Nm. Only 30% difference :-\ .
I've always used 100Nm - nothing happened so far. I'm going to start using 110Nm as it's within 10% of both.
