Thanks for the info, if this is to do with ABS,traction control etc why does the fault manifest itself with the 17" wheels and not with the original 16" wheels?
It is a very good question. Can it be co-incidence? Perhaps you disturbed a ABS sensors wires while fiddling with the wheels? It is extremely strange, I agree.
However, I can't see how the wheel size may affect anything other than tyre pressure monitoring system (yes, this one based on sensing and comparing wheels circumference via ABS sensors). However, for ABS or traction control wheel size makes no difference, it uses relative values, e.g. it can sense if a wheel spins quicker than other, but can't know exact speed.
I had a 17inch alloys for some time on my car and haven't had any problems when installed them, nor when put back the 19inchs. Even more, 19's are staggered, so it is 1985.2mm circumference for rears and 1947.2mm circumference for fronts. Haven't had any issue.
I think code read will give you some idea what was this.
