What're those reflector strips?
just a thought. Were they an option. might sound strange but on my Z , under the front wings there are loose cables not connected to anything in teh area where the side lights would be located. Either that or someone has changed my front end in the past. 😲
It seems that BMW made one loom with all the optional extra bits ready to be used, so there's quite often spare plugs hanging about.
Exactly that, the pre facelift 4 cyl models didn't get those bumper side lights, it was a 6 cyl thing at the time. If you wanted to change your front bumper @spurs fan in a coupe normally has plenty laying around, your after a prefacelift wide mouth bumper.
Oh no. I like the cleaner look without the side lights. I was just curious why some had then and some hadn't.
Or you could just live with the smooth look. Niiiiice.
Exactly that.
Thanks y'all :)
Where is best to buy the side lights? Both of mine have small holes in.
I bought one of these side marker lights in August last year from BMW direct via eBay, turned out to be Park Lane BMW and the cost at the time was £26.20. Hope this helps.
"Buy" a front bumper. :eek: Probably cost more than my car's worth.
I'm sure I could cut them in if I really wanted. But. To be honest. I prefer the bumper as it is. I was just wondering why mine doesn't have them.
What colour is your zed?
As far as I know, a side light, seen directly head-on, (and tail lights) must be within a certain distance of the widest point of the vehicle's body. In total darkness with just the side lights on it's supposed to indicate the width of the vehicle body/frame.
Looking at that picture from @Ianmc the 'side' lights are actually quite close to the centre of the car. Not much use at indicating the width of the vehicle in the dark. But maybe they're just within the distance.
Maybe face lift were just a gnat's doodah and/or wide body versions exceed the limit calling for side lights on the bumper.
Or something like that.
That is why the MOT test refers to front and rear sidelights as “Position” lights, because that is what they do, ie show the position of the vehicle.
My 98 1.9 has no lamps in the bumper front position lamps built into main beam.
My face-lift 1.9 has the lamps in the bumper but not in the headlight units
But after a bit of tweaking have went with the quad side light look which I like the way it looks.
Stephen
