Zmirzephyr
That sounds right for the wheels you have, originally from the M3 in staggered fitment so them tyres sizes are correct. And will be spot on for a set of staggered style 78's. They are the most common sizes for a staggered setup in 17".O I was wrong. Its 245/ 40 R17 at the rear and 225/45 R 17 at the front.
Looks as if they were an option for the Z3. They were mostly found on the E36 M3, called M3 Contours or Style 23.Are the rims I have today stock for my 97 1.9?
With the tyres you have, it is likely they could have been intended for a staggered setup up. In essence, the tyres could fit a whole host of different 17" inch wheels. Some of the combinations will be with in BMW advised parameters and some of them would be on the side of 'stance' or commonly known as stretching. This is typically done to tyre treads to fit under the wheel arch as per MOT law. For some, they like the looks.O I was wrong. Its 245/ 40 R17 at the rear and 225/45 R 17 at the front.
