What is this part called?
Spencer2001
I replaced the bushings on the seats last weekend and noticed there is another part that is broken and needs a replacement, but I honestly have no idea what it is called or how to describe it (what can I say, I’m a physician, not a mechanic)…
It is the plastic piece that the carrier slides into, to attach it to the drive motor unit. It also explains why it was juddering when I moved the seat forwards.
I’ve attached photos … once I know the name, I can order a replacement part
Thanks for your help!
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
The juddering can also be cause by the two sides being just a little out of alignment. This is caused by having a different number of turn counts on each side when you in the nut block.
I've found 9 turns on each side works well.
