What is this for????
Mazza
Bognor Regis
Found this on the floor in the Zed while taking the seats out......
Does anyone know where it goes??
I have gone through all the Realoem parts explosions and cant find it.
It has a screwdriver slot in the top, but it’s just a push in plug
Is it a trim clip of some kind?
OMG don't drive it with that missing.
only kiddin, as grumps says it has fallen out of your trim, it has come out of the plastic covers under the dash (two each side in and under dash - footwell)
As Grumps said Trim clip - if you found it under the seat it's probably from carpet sidewall - look around the door kick plate area. You'll find them used in the boot liner as well.
under here, I have removed mine several times, yes they do need a screw driver to re-insert as the hole is an odd shape (even though they look push fit, push hard enough and they may just push in)
Sorted.....it was the left one in the picture. Thank you all,..... would never have found where it went. Had to be a contortionist to get it put back in.
That’s one rattle less =))
I worked out where it would push into the hole with least resistance, then used a screwdriver and turned it 90deg.
That seemed to have secured it as it stayed put and didn’t fall out again.
