- Joined
- Feb 18, 2016
- Points
- 231
- Model of Z
- Z3M Imola and Z4 (e89)
I am not totally sure but I think this may solve one issue. Look at the underside of the seat and you'll see the "seat occupancy sensor" which is shown in the photo. This needs to be connected in order for the seatbelt tensioner to fire and passenger side airbag (if equipped) to go off in event of an accident. The airbag indicator light will light up on your instrument panel if this is not connected when the battery is connected. The driver's side doesn't have the occupancy sensor the car assumes there is a driver in the car if there is an accident. This image shows it disconnected I think the small white plug inserts where the arrow isHi everyone,
Having the pretensioner light problem and found nothing to plug pretensioner into on passanger car side wiring. Drivers side has White connector (power) and black connector (heated seat) and yellow for pretensioner, all working fine. Passenger side has the white and black (all working) but then also has small pink and small white connector that don't having anything on the seat to connect to? Pink connector has 2 blue wires (one with a brown trace and one with a pink trace), white connector has 3 wires (brown/orange, white/red and blue/pink). It also has wide yellow connector under seat carpet with 2 wire (white and brown.) I just need to identify which wires would be for the pretensioner?? Have attached pics of driver side and passenger side and the male pretensioner plug from seat. Any help greatly appreciated as MOT fail now due to air bag light aebcause of this!!
No idea about the pink one.
