So the heater box has drain holes?Once you’ve removed the scuttle panel you’ll need to poke something into the drain holes to unblock. Then simply clean up and reassemble.
I haven’t even considered this. It makes sense, it’s been quite a few years. Is replacement inevitable you think? I have done little maintenance on my top side from covering it.Top has shrunk
Stephen.
No. The under scuttle space around it does. This is what blocks up and creates a swimming pool.So the heater box has drain holes?
Perfect, exactly what I needed. Thanks
