Washer Pump Leak
bmwz3tower
Hi,
We purchased a 1.9 1997 Z3 Yesterday and overnight it has drained most of it's washer fluid onto the floor. After taking the reservoir out it seems to be the seal between the pump and reservoir that is leaking. After reading over threads on similar issues can't see the seal with the mesh filter attached. Can anyone help find a replacement seal or tell if a seal is missing. Photos of seal, pump and reservoir attached.
Thanks
PS what connector should plug into this socket on the reservoir
mwpe
Camberley
The seal doesn't like quite the same and the reservoir is a different shape - It's the 5l reservoir on the front left of the engine bay. Thanks anyway
If you go to Realoem.com and put your vin number in the search box it will come up with your car. That page is under the electrics section.
