I am surprise at your figure of £100 for a new caliper.Folks, its back!
I got out of the car earlier in the week and there was a distinct burning smell from the brake on the rear driver side. I jacked the car up and the wheel wasn't spinning freely at all.
I removed the slider pins and cleaned them up, and I've also adjusted the handbrake to make sure it isn't dragging on the disc internally. The pads are tight in the caliper, but how do I adjust that?
The caliper seems to operate correctly, although the piston does have some corrosion on it and could probably do with a clean.
I'm minded to replace the caliper, but when I rotate the wheel when the car is jacked up, it rotates and there are patches where the disc is clearly rubbing on the pads, and areas where it isn't.
A new caliper is close to £100 and I don't want to replace the caliper unless it is the caliper.
When I got back today, the caliper was red hot, whereas the opposite caliper was cold.
Thoughts?
P
A few month ago after about 35 miles f/o/s pads started sticking resulting in very bad vibration in steering, the wheel was very hot , the n/s/f was hot but not as bad. Called at a mates to put his thermometer on them , can not recall actual temps but very hot decided to change them.
Went and bought 2 Discs,set of Pads[Pagid] and 2 Calipers from ecp at the rates that day totalling £224 [got refund of £48 on return of old calipers]
Unfortunately this was only 4,000miles after replacing all discs and pads.
Turned out I needed to also had to renew two brake hoses as they were also a bit the worse . Got BMW parts to be sure but one did not fit ,resulting mate making a new hose,fortunatly he has all the equipment to do that.
Just hope the rears dont need doing , they are double the price of fronts if I recall the comments at ecp counter correctly
