Vanos torx bolts on intake solenoid
Crispie
Poole
Hi all,
Firstly, please ignore the big arrow in the pic below. I borrowed it from google.
Question is - does anyone know what these 3 torx bolts do, and what happens if i took one out? Specifically the top one.
Will it fall apart inside the vanos or is it just a blanking screw?
Any info much appreciated.
Chris
I am not sure Chris but I would not remove anything. Why would you risk it? If you mess with the oil supply to the vanos, well let's just say you might as well start looking for a replacement engine now.
On a lighter note, this guy messed with his vanos and look what happened to him! lol
View: https://youtu.be/pXMW-Xpu9xU
Always thought LPG was slightly dangerous inside the car.
Thanks for the comments guys.
Just a slight weep from the top bolt and before I had chance to investigate, thought i'd put a question out there.
I haven't found what's under the bolts, however to sort my problem i found one had loosened a bit so it just needed nipping up.
For now, I think that's sorted my problem.
Cheers
Chris
ps
this was after doing the VANOS job.
driveability is much better. revs are more stable. power is consistent.
