It is both. There ore large O rings under these flat type gasket rings. Perhaps they are scraper rings.
It should make a difference if oil pressure is not maintained as designed as the vanos will change the cam position. Oil leaks equals cam position inefficiency . That's why the engineers out it in the car.
In a few days I can let you know if it makes a difference to fuel efficiency as I keep meticulous records. So far it is looking good. The car pulls like a team of oxen however it was a neck breaker before I rebut the vanos. !
