Hi again Folks, when I took my old wheels off I noticed that one of the rear tyres was badly worn on the inside only. Any thoughts on which component of the rear suspension may need attention?
The car is running on standard suspension but with 15 mm spacers and only one side is showing uneven wear. That is whatmakes me think that something is worn.......If it has been lowered then it does alter the camber i do believe this is normal unless like you think a component has failed
I have followed a few zeds that have been lowered and it is quite noticeable when you drive behind them some more than others
unfortunately the yokahamas I now have fitted can only run one way.It's a must to turn Z3 rear tyres on the rim, especially if you have spacers fitted to get the best mileage out of them. The rear suspension has in built negative camber, but spacers exaggerate it.
That's not a problem Nige, I had directional tyres on my Z3, you just remove the tyres from the rims and turn them to the opposite direction and fit the wheels to the other side of the car. If one tyre is wearing worse than the other you may have an arm bush or similar problem. How big a difference is there in tread depths?unfortunately the yokahamas I now have fitted can only run one way.![]()
Thanks Tony, one side is about 1.5 - 2 mm more worn than the other, may be worth getting the back end set up, not been done for a couple of years.That's not a problem Nige, I had directional tyres on my Z3, you just remove the tyres from the rims and turn them to the opposite direction and fit the wheels to the other side of the car. If one tyre is wearing worse than the other you may have an arm bush or similar problem. How big a difference is there in tread depths?
Me too, I am at 99k and thinking about a full suspension rebuild.When I've had mine on the wheel alignment ramp both rear show negative camber but nearside is out of tolerance that's the one I have the most inner edge wear on 92k on mine original rear end plan a rebuild end this year see where I am after that .
To be honest I wouldn't be too concerned, have you owned and used these tyres for all their life?Thanks Tony, one side is about 1.5 - 2 mm more worn than the other, may be worth getting the back end set up, not been done for a couple of years.
perhaps I will stop worrying about it!There is nothing to adjust on the rear of a Z3 mate.
The point I was making mate was perhaps that particular tyre had some previous wear (maybe from being on the front?) and once a tyre starts to wear in a particular way it will continue whatever adjustments you may make. Keep a close eye on your new tyres and you may well be pleasantly surprised that you have little to worry about.perhaps I will stop worrying about it!Got the tyres with the car 3 years ago but they seemed ok at the last2 mot's. I think I will go under next weekend and have a wiggle at the back end just to satisfy myself. Thanks again Tony
I see what you mean Tony, you could be right. I will keep an eye on the new ones as you suggest. Many thanks for the help!The point I was making mate was perhaps that particular tyre had some previous wear (maybe from being on the front?) and once a tyre starts to wear in a particular way it will continue whatever adjustments you may make. Keep a close eye on your new tyres and you may well be pleasantly surprised that you have little to worry about.
I had a similar experience - inner treads gave in vey quickly after being on the car 3 years - don't how long the tyres had been on before I bought it - I've 20 mm spacers on and the car is lowered.perhaps I will stop worrying about it!Got the tyres with the car 3 years ago but they seemed ok at the last2 mot's. I think I will go under next weekend and have a wiggle at the back end just to satisfy myself. Thanks again Tony
Hi David, what concerns me is that its only on one side of the car on mine so might be a component failure.I had a similar experience - inner treads gave in vey quickly after being on the car 3 years - don't how long the tyres had been on before I bought it - I've 20 mm spacers on and the car is lowered.
mmmm? not sure, I will check. What are you thinking?Does the car sit flat if you measure from arch to ground either side at the rear ?
Was wondering @t-tony - did you adjust the camber with lowered suspension and/or spacers fitted? I presume you'd try and get closer to the BMW settings to reduce the impact of the geometry changes from spacers and lowered suspension.It's a must to turn Z3 rear tyres on the rim, especially if you have spacers fitted to get the best mileage out of them. The rear suspension has in built negative camber, but spacers exaggerate it.
No mate, the K&W suspension was already on the Z3 when I bought it, I added the spacers a couple of years later and just managed the tyre wear as I described. There is no adjustment on the rear of a Z3.Was wondering @t-tony - did you adjust the camber with lowered suspension and/or spacers fitted? I presume you'd try and get closer to the BMW settings to reduce the impact of the geometry changes from spacers and lowered suspension.
