- Joined
- Sep 25, 2019
- Points
- 100
- Model of Z
- 3.0
Yes - seen... Good Job! ThanksHave a look at my thread, I did a full underside protection
https://zroadster.org/threads/introducing-rhubarb.13136/page-9#post-414439
Good news with the MOT pass. You can breath easy on that score.
So you’re mothballing your Z for winter?
Thanks Ttony - very pleased with what I found so far. Fingers crossed for the other sideThe car looks to be in very good condition Michael, great work
I sure will - the screws look very clean but I’ll give them a good spray and leave them before I try to undo them. Had a few challenges today getting everything off but some great tips on here. If the weather holds I’ll do the other side tomorrow and then get stuck in to the cleaning etc. It will definitely be easier now I’ve done one side!Good stuff Michael. Looks in fine fettle! It might be worth carefully removing the jacking point pads while you are looking at the sill area.
If you do, I would recommend spraying the self tapping retaining stud plastic nuts on the rear pads with generous amounts of WD40 and leave it to soak.
I still managed to shear one off each side even then, but it does mean you can clean everything of accumulated grime and apply the dinitrol to all the metal.
Not sure I would use POR-15, in fact I didn't, I have seen some horrors with it appearing still to be rock solid but water getting underneath it.Might be of interest this process but I would use other products than used on here but shows you how water can get under some of the existing under sealant
View: https://youtu.be/YLAPGqakYXw
I see, a bit like the plastic arch covers keep most of the dirt away but what gets behind it is trapped and start of the problem.Agree with @Nodzed I did my rear subframe on the zed with POR15, prepped it as recommended using their products and its still starting to peel in places (driven less than 5000 miles since the refurb)
Once the paint has peeled moisture will get under these areas and rot out the metal underneath.
