Undercarriage splash shield missing - is it two covers?
elky
Copenhagen, Denmark
2001 Z3 3.0i Roadster
Does anyone still have their splash shields (under the engine) that wants to share a photo?
I am looking at hubauer.de and am confused about how many pieces I am missing. Basically, under my engine, I don't have any plastic covers.
Finally, would you say they are worth their value to have them?🙄
elky
Copenhagen, Denmark
The 3.0 doesn't have a shield under the engine, only the front one, part 2 in the diagram.
OK thanks a lot for answering my question because I was puzzled! Then probably the previous owner lost it somewhere because mine doesn't even have that. Do you think its worth the money to replace it?
Ianmc
New Forest
Z3 (M44)
I guess it was designed/fitted for a reason?
I’ll bet there are more running without the splash guard than with it. If you can locate one cheaply get one, other wise don’t bother.
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
No 2 is called an air scoop, it supposedly directs air flow into the radiator. Depending on the condition of yours, you may need parts 4 & 5 as well as the scoop attaches to these and the bumper.
These plastics get brittle over time so finding a secondhand set in good condition may be an issue.
Mine decided to part company with the car years ago and I haven't replaced it. It hasn't had any noticeable effect on cooling.
elky
Copenhagen, Denmark
Thanks for a
Indeed its called an airscoop, I haven't found any second-hand locally (except from eBay) but I can find new OEM air scoop for 120euros and that is why I am contemplating 🤔 But from what you say I understand I have to take a closer look next time I lift the car and see what other plastics I am missing...🙄
AntStark
Hampshire
2002 3.0 Sport
Assume you have either part 1 or part 2 but not both. Mine has part 2
lalinsorinoco
Hampshire
Z3 1.9 Orinoco
Mine (1.9 M44) still has it. looks like its part 6... :coolsteer)
