- Joined
- Feb 18, 2016
- Points
- 246
- Model of Z
- Z3M Imola and Z4 (e89)
Ever fixed something and don't know how you did it? Well just had one of those moments. I have a PURE Highway DAB radio in my Zed with an active screen antenna. But I have never been able to get the DAB side of the radio to scan for stations, it always said on the screen no signal, but this was not an issue because the FM side worked just fine (but I have always been a bit hacked off it didn't work if I was honest
) So it was on the list of jobs to remove the radio at some point and check all the connections etc etc.
Well as I fitted my new steering wheel the other day I had to disconnect the battery so I didn't end up with a face full of airbag when I disconnected it from the steering wheel (thank you again @Mint for the advice
) well, all went well with that modification but I remembered today I hadn't changed the radio and analog clock back to the correct times following the radio disconnection and being a bit OCD though I'd just pop out and sort that.
Sooo turned on the radio to adjust the clock and it started up in DAB mode, tuned its self in and bingo I now have a fully working DAB stereo
Haven't got a clue why disconnecting the battery sorted, unless it did a factory reset? So next time our IT department tell me to "ToTo" my laptop when it plays up I wont take the p*** out of them.
